Error -1950678985
Guys,
I am new to Labview and have a project to complete. I am following the instructions for creating bound variables from the "Getting started with LabVIEW Datalogging and Supervisory Control Module".  I can create some bound variables but others give me the error code 1950678985. The only hint the message gives is that it may be an invalid name that I am using e.g using a \ in the variable name. I have checked this and I can't see anything wrong. Does anybody know of any other reason for this error ?
(3,322 Views)
what version of LabVIEW are you using?
(3,311 Views)
Labview 2010 32 bit. I have been told by one of my colleagues to change the label format if I have it on more than one line i.e. compressor
                  station
to compressor station. Some of the labels are like this but it will be a couple more hrs before I get home to try this.
(3,305 Views)
Problem solved. I renamed some items using only one line and had to delete and re-insert others.
(3,298 Views)
Can you tell me what you did exactly.
I have the same problem when I switch from a Labview 8.2.1 to Labview 2010.
The project made in Labview 10 are causing an error.
You can see a screenshot of this error in the attachments.
If you have any idea what the problem can be, please let me know.
Kenny
(3,282 Views)
Kenny,
I hd some descriptions which were written on more than 1 line to keep them tight. I had to change these to one line only. Other items I just had to rename or reinstall. Sorry I cant be more specific but this is as much as I remember.
(3,268 Views)
