Error -1950678965 Shared Variable
I have a VI that reads a SV array. If I just plop this down on a blank vi and hit the run key it works fine with no errors. But when I put it inside of a loop it runs once then gives me this error. It doesn't matter how long of a wait I put into the loop. I've tested it as long as 5 seconds and it always errors after the 1st iteration. If I just run it manually I can hit the run button as fast as I can it does not error. Smiley Indifferent
PaulG.
Retired
(3,102 Views)
There is bug fix 130186 for this error
(3,084 Views)
