Error 1502
I am facing following error: -
Error 1502 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Save.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_Create_Build_Application.vi -> EBUIP_Global_OnCommand.vi -> EBUIP_Global_OnCommand.vi.ProxyCaller
Possible reason(s):
LabVIEW: Cannot save a bad VI without its block diagram.
Please suggest solution for the same.
(2,832 Views)
Hi NarendraDhayal,
Could you provide some background on when you are recieving the error, what version or LabVIEW you are using, if it occurs when saving, building or creating an executable. and/or what toolkits you are using? Without providing background information it is extremely difficult to propose a solution.
Also have you tried the steps in other forum posts about enabling debug and checking dependencies?
http://forums.ni.com/t5/LabVIEW/Build-error-1502-but-no-broken-VI/td-p/450498/page/2
http://forums.ni.com/t5/LabVIEW/bleep-you-error-1502-shakes-fist/td-p/1404652/page/2
http://forums.ni.com/t5/LabVIEW/Error-1502-occurred-at-AB-Source-VI-lvclass-Close-Reference-vi/m-p/2...
http://forums.ni.com/t5/LabVIEW/Building-LV8-5-application-EXE-error-1502/m-p/2387406
- FCTesting
(2,793 Views)
