Error 1335 during installation of NI LABVIEW Run Time Engine 2009
While installing Labview 2009, I am getting the following error.
Error 1335 : The cabinet file 'mib100.cab' required for installation is corrupt and cannot be used. This could indicate a network error, error reading from CD -ROM, or a problem with this package.
I tried installing the software using 2 different CD-ROMs and also from the hard-drive. I also uninstalled previous NI software and tried installing Labview again.
Attached is the screenshot of error during installation from hard drive.
Thanks in advance,
Sayali D
(6,099 Views)
Have you tried it on another pc to see if there might be a problem with your DVD reader?
(6,098 Views)
Yes, installation was successful on other PCs before.
(6,091 Views)
Well, there you go.
(6,085 Views)
So, shall I just try installing it from a netwrok drive?
Sayali D
(6,082 Views)
Or replace the DVD drive in your system.
(6,080 Views)
Accepted by topic author Sayali
The installation was successful after replacing the DVD drive.
Thank you!
Sayali
(6,049 Views)
