Error 1305 while installing LabVIEW 7 in VMware Workstation 4
While installing LabVIEW 7 in a clean Win2000 virtual machine using VMware 4.00, I get 'Error 1305. Error reading from file C:\WINNT\System32\ninetbrw.ocx. Verify that the file exists and that you can access it.'
This happens at 'Part 7 of 11'
I tried LabVIEW 6i in a clean Win2K VM, and it worked w/o a problem.
(3,910 Views)
Trying running the installer and note down what is part 7. Once you get error, it will ask you if you want to continue. Choose YES and it will install the rest of the parts.
Try running the part that gave you error directly from the CD (under "components" folder).
You can also generate log file to get more detailed information. use following command line (example for app builder.msi)
msiexec /i lvappbuilder.msi /l*v c:\lv70.log
Hope it will help you.
ARafiq
(3,910 Views)
Also try turning off Raw Access for the CD drive in the VMWare configuration options. That has been known to affect CD reads.
Naren
(3,910 Views)
I was able to install w/o any errors by copying the entire CD to the hard drive first.
(3,910 Views)
Dear Sir/Madam,
Please let me know if you wish to use my services as a experienced labview
programmer 3x - 7.0. 3 years experience in Automotive and RF,
communications field. Electronics & Instrumentation technologist looking for
work as a test engineer or any related areas.
Please contact me for resume and further information at
nav_rehal@hotmail.com
regards,
Nav.
(3,910 Views)
