Error 1172 when click on Processes tab in SimpleTaskMonitor.vi
I'm trying to run the SimpleTaskMonitor .net example that comes with LabVIEW 7.0. When I click on the Processes tab while the vi is running I get the following error:
Error 1172 occurred at Exception has been thrown by the target of an invocation.>> Cannot read Instance :CSDispatcher. in SimpleTaskMonitor.vi Possible Reason(s): A .NET exception occurred.
How do I fix this problem?
I have Microsoft .NET Framework 1.1, Microsoft .NET Framework Hotfix (KB886903) and Microsoft .NET Framework SDK (English) 1.1 installed and am using LabVIEW 7.0.
I had been getting a message when I opened the vi that the System, Version 1.0.3300.0 assembly had not been referenced, but I found a link on NI's website that said to double-click the PerformanceCounter constructor nodes in the vi and select the appropriate constructors from System, Version 1.0.5000.0. I did that, which made the message when I open the vi go away, but I still get the above error when I go to the Processes tab while the vi is running.
Thank you for your assistance!!
JesseB
(4,107 Views)
Could you check your process list in the task manager and see if you have a process called CSDispatcher? My guess is that we are getting a security error or something when trying to get the process information from that. I searched the web and all I can find is a reference to a Delphi tool called CodeSite.
Past that, I am afraid I only have the "It works here". But we can try to isolate it more on your machine...
(4,100 Views)
Yes, I did have a process running called CSDispatcher! Once I stopped that process and a couple of other, related processes the SimpleTaskMonitor.vi works fine. Thanks!
Any idea why the vi wasn't able to "read" those processes though? If I use the GetProcesses.vi in a different vi is there a danger that the user is going to have some process running that causes this error? Is there a way to avoid this?
Thanks!
JesseB
(4,095 Views)
I am not sure, but I would guess it is something inside of .NET (either the Win32 or WMI underpinnings) and security. If you want, I can write a little test program to try to isolate down the problem. Just shoot me a mail if you do so I know where to send it.
Brian
(4,092 Views)
For those that might be interested, we've been able to isolate it down to a Win32 issue and CSDispatcher. Using a straight C# application, we get
Received an exception: System.InvalidOperationException: Cannot read Instance : CSDispatcher.
at System.Diagnostics.CounterDefinitionSample.GetInstanceValue(String instanceName)
at System.Diagnostics.PerformanceCounter.NextSample()
at System.Diagnostics.PerformanceCounter.NextValue()
when trying to read the "Private Bytes" value. I am not sure if it is a bug with the Win32 Perfmon provider or something that CSDispatcher has done to disable that counter.
(4,079 Views)
