Error 113 - UDP
I am currently using Labview 8.20
I am reading a text file and sending the contents of that file using UDP.  The file is big and I get the
Error 113.  " A message  sent on a datagram was larger than the internal buffer or some other network limit,
or the buffer used to receive a datagram was small that the datagram itself".  If I use a small file, it works.
I am fairly new to Labview and I just modified the code in the Examples for the UDP Sender and
I am using the UDP Receiver example.
I am using the Read From Text File VI and connected it's output text to the UDP data in.
Any ideas?
Jaime
(3,412 Views)
Hi Jaime,
First of all, are you positive this is LabVIEW 8.20? I have noticed a similar issue that was resolved in LabVIEW 8.0... Are these two PCs both on the same OS and both with LabVIEW 8.20?
Assuming so, how large of a file are you transmitting using UDP? Have you seen what the threshold might be for causing this error? Also, try increasing the max bytes/read and see if that helps.
Sam
-Sam F, DAQ Marketing Manager
(3,398 Views)
