Error 1097 when calling dll
I'm using more than 20 functions from a .dll code to Labview and have in some of then the 1097 error.
Error 1097 occurred at Call Library Function Node
Possible reason(s):
LabVIEW:  An exception occurred within the external code called by a Call Library Function Node. The exception might have corrupted the LabVIEW memory. Save any work to a new location and restart LabVIEW.
I have read a lot about this error and I still didn't find a solution.
Thinking that could be a problem on the configuration of the VI, I imported it again and this solved the problem in the first VI. I did the same with the second one with an error but this time didn't solve.
The weird is that this VI with the error (intRun):
_API void intRun_ ( int* run_ , int* devList_ ,int* numDev_, char* retval )
it is exactly the same as another (anaRun) and this I don't have the error:
_API void anaRun_ ( int* run_ , int* devList_ ,int* numDev_, char* retval )
Inside the C code they look like the same (but each function will run a  different device) and the configuration in Labview is also the same.
Is that possible that I have any problem with my device? Or could be really a problem with the .dll or with the VI?
I read something about wrappers but really I don't understand why I have the error with one VI and don't have with the other (running together) and how (or if) the wrapper could solve my problem.
Please give me any idea what I could try.
For example, I tried to disconect the input numDev (that is a constant, always 1) and then I don't have the error. Why?
Best Regards,
Thais
(5,107 Views)
Can you attach your VIs, showing how the call library function node is configured, the header (.h) file for the DLL, and if possible the C code for the functions that return an error?  That would help us provide useful suggestions.
(5,100 Views)
Can you tell me your LV Version?
Maybe this link can help you:
http://digital.ni.com/public.nsf/allkb/D84C9775ABD921CF8625772A005CA50C?OpenDocument
Philipp
(5,067 Views)
Thank you for reply.
I'm using LV09.
Actually I figured out that before this VI that I have the error the device is not working as should be .
When running the program step by step I realized that what I was expecting to happen (locking ports before initialization) didn't happen.
So it is probably a bad configuration of the other VIs that I have (there is no Error but returns me an Bad Argument in the return_output);
I will try to solve it and then I tell here if it was really that.
Thak you all.
Thais
(5,062 Views)
