This is an offshoot of this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=145602
Since that issue was cleared up, I've run across a new error claiming
my AC Load is not present. Again, this exact same Labview program
worked fine before, so my first instinct is that there is still
something that needs to be loaded that is missing.
Some background:
- I am using a new PC, and this is my first attempt at
running a Labview VI on it.
- This same VI functioned without incident on my previous
PC (which died).
- I'm using Labview Express 7.1.
- I'm using a GPIB inteface.
What I've tried so far to solve the problem (all of which
have failed):
- Uninstalled and reinstalled Labview.
- Downloaded and installed NI-VISA 3.3.1 driver (latest
version).
- Confirmed that MAX 'sees' all the correct instruments on
the GPIB connection (Labview engages remote control of my instruments, and
responds to *IDN? queries, so I'm guessing that comm isn't an issue).
- Confirmed I have the latest IVI Compliance Package loaded.
- Confirmed that the function name and parameters in the
Library Call Node are correct (they worked before), and that the calling
convention is correct.
- Built a new VI from scratch that just employs the Library
Call Node (and required inputs and outputs).
- Alternately sweet talked/cursed at the monitor.
Here is an NISpy capture of the problem:
Any suggestions?
