Error-1073807338
Afternoon,
   I'm currently supporting a client on site who is getting a VISA driver error message. The error starts as "Error - 1073807338 occured at VISA. Clost in Advanced Serial Write and Read.vi SubVI2.vi-> MAIN PROGRAM.vi". I've attached an image and the error log file. Any suggestions is gratefully appreciated.
Best,
   Joao da Silva
(4,922 Views)
Hello Joao da Silva,
Error -1073807253 is a framing error. Serial data is transferred one byte at a time. Each byte has a specific format with a start bit, data bits, parity, and stop bits. A framing error occurs when a byte of data is received, but it is not in the format expected.
Have you tried the application in another computer, or force reinstalling NI-VISA in the computer that your client is using?
(4,874 Views)
Hello Oscar,
But the error message you posted is not the one that the OP is asking about.
The error message is:
Error -1073807338 occurred at an unidentified location
Possible reason(s):
VISA:  (Hex 0xBFFF0016) The VISA driver failed to properly close the session or object reference. This might be due to an error freeing internal or OS resources, a failed network connection, or a lower level driver or OS error."
That is an error I've never seen before and would indicate a deeper problem with the drivers.
(4,870 Views)
That's correct, RavensFan
I would still try in another computer, and force-reinstalling NI-VISA (and NI-Serial/NI-488.2 depending on the protocol they're using).
That way we can know if the error relies in a corruption in the driver, or if the application is performing tasks in an unsupported way. What do you think?
(4,867 Views)
Anyone get to the bottom of this?
I have a usbd cdc acm serial interface to a NordicSemi dongle that I programmed, and I occasionally get this error while pushing commands from the client on a LabVIEW VISA interface. Funny though, because a serial PuTTY interface never causes the error.
As an interesting side, the error is almost always associated with a fatal error on the dongle (the usbd interface). The dongle shuts the port and restarts the embedded application I programmed.
Not sure if it's the LabVIEW driver causing the connection to drop, but I don't get this error with other serial drivers. Maybe you should try alternates (PuTTY, RealTerm, HyperTerminal) to see if the behavior is consistent?
(4,160 Views)
