Error -1073807252 occurs intermittently
All,
I am using a LV program to receive a comma delimited string (approx.
16KB) from an embedded board. I have been using the "Advanced Serial
Read Write VI" to read the data after proper handshaking. And XON/XOFF
flow control is in place.
This program was running fine for a few weeks now. But it has suddenly
started to develop this error.
>> 1073807252 VISA: (Hex 0xBFFF006C) An overrun error occurred during transfer. A character was not read from the hardware before the next character arrived.
Nothing on the LV or embedded side has changed (AFAIK).
This problem is intermittent. So the program works fine for an arbit
amount of time before it breaks down (making it a pain to debug). When
it does break down, it receives a truncated string which is sometimes
1KB and sometimes upto 12KB (so I seriously doubt if it is a buffer
issue). I am also using the "VISA Set I/O Buffer size" to set the
receive buffer size. Is there a maximum value I can set this to? If I
set it to a number above the maximum value, does it revert to default
(4096)?
The intermittent nature of the problem suggests that it is more of a
timing issue than anything else. But here, I am attempting to read the
entire chunk of data at once and there is no processing time involved
between reading succesive characters. Hope somebody can bail me out.
TIA
Vijit
(3,225 Views)
Hi
I suffer from the same problem. I think it is a bug.
I need a soluon immediately
(2,855 Views)
Why bump an extremely old thread?
Yes, it's probably a bug in your code. Why didn't you attach it?
(2,847 Views)
