Error 1073807190
I am attempting to run my program to control an Anritsu 37XXX series Vector Network Analyzer (VNA) in conjunction with Quantum Design's Versalab. I have already downloaded the drivers and sub-VIs published by both manufacturers and implemented them into my program. When the program attempts to initialize the VNA, an error message occurs: Error 1073807190 (see attached screenshot).
I see only one other post about this error code, and following its suggestion, I changed out the GBIP-USB interface connecting my CPU to the VNA. This did not fix the issue however; the error code appears no matter which cord I use.
I have attached my VI, for reference, along with screenshots pointing to where the error occurs within the sub-VIs (with context help window open).
Are there any other recommendations for addressing this error code? Are the sub-VIs I'm using just outdated?
Message 1 of 1
(961 Views)
