Error 1048 occurred at LabVIEW: LabVIEW failed to get variable from the script server. Server:"" in MATLAB Script Node - Fractal.vi
It worked before.  What happened?
LV 8.6 on Windoze XP
(5,881 Views)
I still don't get it.  Notice that  I get the error with Fractal.vi.  This is the matlab example code.  It worked just fine last week.
I think somethings hosed with my axtive X server connection to Matlab.  Before, running this script would fire up a command ML window.  Now it doesn't.  Is this because I tried to run it while I had the matlab editor/debugger running?
(5,874 Views)
I shut down and restarted labview.  Fixed the problem.
Can anyone tell me what happened?
(5,863 Views)
