Error 1047 occurred at LabVIEW: LabVIEW failed to send variable to the script server. Server:"" in MATLAB script node - Lorenz Diff Eq.vi.
I am using Matlab R2009b and Labview 2011.how to solve this problem?
(6,723 Views)
I can't answer specifically, but it seems curious that the server name in the error message is empty. Can LV talk to Matlab at all?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,695 Views)
It is giving me" LabVIEW cannot initialize the script server.  Ensure the server software is installed" as a possible reason.Can you tell me how to do this ?
(6,687 Views)
Do you have Matlab  installed on the same computer that LV is on?
Mike...
LabVIEW Champion
(6,681 Views)
yeah both are present on c:\program files(x86).is there any way that i can specify a path for Matlab?(if thats what is needed)
(6,673 Views)
That should be in the documentation.
Mike...
LabVIEW Champion
(6,663 Views)
