Error 1045 Using Report Generation Excel 2010
The attached code throws an error 1045 when using Excel 2010.  I don't get this error when using Excel 2007.
Please Advise
Dan Shangraw, P.E.
Message 1 of 8
(5,844 Views)
Take a look at this Knowledge Base article and see if if helps.
Error 1045 When Using Report Generation Toolkit for Microsoft Office
http://digital.ni.com/public.nsf/allkb/3E4102D8B91D0F9E86256CE0006BADCB
Message 2 of 8
(5,826 Views)
We tried that but still got the error
Dan Shangraw, P.E.
Message 3 of 8
(5,815 Views)
Can you give a description of your overall application?  Also, have you tried to run the code with highlighted execution turned on to see where the error occurs?
Message 4 of 8
(5,789 Views)
This error only happens using Excel 2010.  I am using Excel 2007 and it works fine.
It semms to be occuring during the save Report or Close Report VI (see attached VI).
Dan Shangraw, P.E.
Message 5 of 8
(5,777 Views)
Hey there
So, any solutions or suggestions?
I`ve got this error too, but this time using MS Excel 2007. I`ve checked KnowledgeBase article. Error occurs while disposing report function/
Message 6 of 8
(5,556 Views)
ASTDan
Just downloaded and ran you code and it seems to work fine under LV2012, Windows-7, Office-2010.  What version of LV and OS are you using?
Message 7 of 8
(5,544 Views)
One thing I observed I get the error when I had the window state set to "minimized".  When I changed the window state to "no change" the error went away.
Dan Shangraw, P.E.
Message 8 of 8
(5,501 Views)
