Error 10444 (no more memory)
Hello everyone
I get the error 10444 after my VI has been running for some time. It
says the error occured in AI config VI.
I understand that the buffer is full after some time but I'm just using
one point AI and so don't understand what kind of buffer LabView ist
filling up. All the parameters are set to "don't allocate memory".
Thanks for your help
Paul
(3,520 Views)
This can be that you have fragmentet your memory so badly that the memory
manager could not find any suitable continous block of memory for this
task.
Happends when you have little memory in the computer and/or doing a task
that alloc and dealloc memory wery often combined with some other tasks
that
also use memory in between. The cure is to minimize the memory overhead on
what
you doing and check preferenses if you have "dealloc memory as soon as
possible"
on, i have to use this in off because of fragmentation of memory in some
of my projects. Open "one point AI" and check if you can split up the vi
into one
"init" and do that one one time only, and a "read" wich you use when you
have
to get new values.
Paul Steiner wrote:
> Hello everyone
> Paul
(3,520 Views)
Get memory defrag utility on shareware site. I think mem-turbo or something
like that, never expired, just nagged once in a while.
"Janne G" wrote in message
news:3814615A.19EFB46A@cad.luth.se...
> task.
> that
> what
> possible"
y in some
> into one
> have
> to get new values.
> Paul Steiner wrote:
> > Hello everyone
> > Paul
(3,520 Views)
