Error 10403
I am trying to use some of the examples of the Solution Wizard. I keep
getting the folloeing message when using device PCI - 4451, for the Data
Logger :
" Error-10403 occurred at AI SingleScan.
Possible reasons:
NI-DAQ LV: The specified device does not support the requested action (the
driver recognises the device but the the action is inappropriate for the
device)."
Any suggestions ?
Thanks in advance,
M.
(3,122 Views)
I suppose you are using the examples tht match with your hardware, so the problem could be that your hardware is not correctly configured, or that it doesen't support the actions you are asking from LabVIEW, you should check inside the example, run it in highlight mode and see which command makes it fail, so that you can see if your instrument supports it.
Good luck
(3,122 Views)
The answer to your question is best answered by one of our online web support resources, the KnowledgeBase. If you go to:
http://www.ni.com/
and click on 'KnowledgeBase', you will be taken to a page where you can do searches for information on issues such as these.
Do a search for 1ESCEL0O, which is the document ID of a KnowledgeBase entry on this issue.
Also, in the future, you will get faster response times to your Developer Exchange postings if you classify them in the correct category. DSA has its own category, as do general purpose Data Acquisition (DAQ) questions. The LabVIEW category is usually for purely LabVIEW programming questions that don't involve any hardware aspect.
(3,122 Views)
