Error 1003 when building executable
Hi, I'm using Labview 2010 on Windows 7 and I'm getting an error when I try to build an executable:
Error 1003 occurred at Open VI Reference in AB_Engine_EXE_Call_Write_Icons.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Create_Build_Application.vi->EBUIP_Global_OnCommand.vi->EBUIP_Global_OnCommand.vi.ProxyCaller
Possible reason(s):
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Select File>>Open to open the VI and then verify that you are able to run it.
VI Path: C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\Platform\icon.llb\Read Icons from ICO File.vi
This happens even when I try to build a simple vi, like a random number generator.
(4,298 Views)
Happens to me sometimes, I close LabVIEW and re-open it then it works...
That's not much help, I know...
Epictetus
Antoine Chalons
(4,294 Views)
Same problem here. Error 1003 and error 8 I encoutered often.
For error 8 during build process, I needed to save the executable on a higher level in the file hierarchy.
For error 1003, I did not find a solution. Restarting LabView does not help. Sometimes (but not always) restarting the computer helps. Sometimes I need to reinstall the labview system.
More details: I have a first vi, starting the actual vi with a hidden front panel (second vi). This vi can also be started directly. Sometimes, the build process runs smoothly then  when I include the second vi as main vi to start the program.
The program runs fine when the build process succeeds, and it runs fine in LabView.
(4,266 Views)
NI solved this for me.  It turns out I had corrupted files way down in the icon.llb.  The VIs in that llb had broken arrows. Although they did not result in a broken arrow in the VI I was trying turn into an executable, they prevented a successful build.  They sent me an uncorrupted file and the build worked.
(4,260 Views)
Thanks for your answer.
I relinked a library, now it is compiling. The new library is identical with the old one, but located at a different place in the file system. I do not see the reasons it did not work previously....
How did "Ni" find this error? I performed a mass compile, without any obvious errors....
brauni
(4,257 Views)
Again, this llb was not a subVI of my program, but still prevented it from building an executable.  So it makes sense that you could do a mass compile.
(4,239 Views)
