Error 1003 occurs when use "target relative" shared variable in LV8.5
I create a network share varible. If I changed its properity into "target relative", then the Error 1003 occured when I built it into a exe application. And if changed it to "absolute", then it was fine!
Is that a bug in LV8.5 ? or somethin wrong I did ?
(3,702 Views)
I received a few 1003 Errors a while back...
"The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Open the VI in LabVIEW using File»Open and verify that it is runnable."
I can't seem to recall what I did to have the error or what I did to fix the error, but if everything is working fine for you then I'd be happy with that.
(3,691 Views)
Dear,
I found this link regarding shared variable. Hope this helps you.
http://zone.ni.com/devzone/cda/tut/p/id/4679
Mohit Monga
(3,596 Views)
