Error 1003 occurred ...\internal.llb\DAQmxBase Start Task 92xx.vi
I got this error while trying to make a exe out of the example "Cont Acq&Graph Voltage-Int Clk.vi". I have tried the workaround mentioned in the KB article about the USB-92xx Bulk Reader thing but that does not help.
Is this a known issue ? Seems like nobody else have this issue ?
(2,245 Views)
Hi Seethoo,
Follow the steps listed in the following KnowledgeBase: Error 1003 Occurs When Trying to Create an Executable.
Make sure to especially do the last step (I have seen this to be the solution in the past).
Hope this helps,
Travis H.
LabVIEW R&D
(2,226 Views)
