Error 10 when building app with Report Generation _wordsub.llb in the project.
Error 10 occurred at ABAPI Dist Copy Non-VI Files.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI Copy Files and Apply Settings.vi -> SDBEP_Invoke_Build_Engine.vi -> SDBUIP_Build_Invoke.vi -> SDBUIP_Build_Rule_Editor.vi -> SDBUIP_Item_OnDoProperties.vi -> SDBUIP_Item_OnDoProperties.vi.ProxyCaller
 This is the error I get when a set up _wordsub.llb to use of report generation in a build project.
(3,362 Views)
Hi Dave,
what Version of LabVIEW are you using?
Stefan
Impossible is nothing - nothing is impossible
(3,345 Views)
Hi Stefan,
       LV 8.0.1 Pro with report generation toolkit installed.
Dave..
(3,344 Views)
Instead of adding _wordsub.llb to your build, try adding _wordsub.llb\_Word Dynamic VIs.vi as a dynamic VI.  This should work.
-D
(3,334 Views)
Dave,
thanks for providing me with this information. I didn't hear about this error in the past, but I found a KB, that possibly can help you debugging the application: http://digital.ni.com/public.nsf/websearch/AF12BB5FAC27FE2186256F9400619C84?OpenDocument
Let me know, if it helped you out
Stefan Smiley Happy
(3,330 Views)
Thanks to Stefan and Darren,
 I looked at the link and removed a reference to one of the paths and both disappeared from project along with the error 10, but the app did not work when build.
I then took Darren suggestion and that seem to do the trick.
Thanks Dave C
(3,316 Views)
