Error 10 when building an application in LV8 and Report generation toolkit 1.1.1
I am trying to build an application using LV8.0.1 and Report generation toolkit 1.1.1 and i get this error.
Error 10 occurred at ABAPI Dist Copy Non-VI Files.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI Copy Files and Apply Settings.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Invoke.vi.ProxyCaller
Any ideas?
Scientia est potentia!
(2,955 Views)
Did you attempt to add the _wordsub.llb and _excelsub.llb files to the application as support files?  I believe in LabVIEW 8.0 instead of adding the entire LLBs you should just add the _Word Dynamic VIs.vi and _Excel Dynamic VIs.vi as dynamic VIs.  I think I've seen a similar post on the discussion forums in the past that recommended this.
If this suggestion doesn't help, please reply, and attach a simple VI and .lvproj file demonstrating the problem so I can investigate further.
Good luck,
-D
(2,953 Views)
It worked. Thank you.
My mistake was to follow what the Report Generation Toolkit User Guide tells me to do: add the LLBs instead of the top level VIs.
(2,943 Views)
Yes, we currently have a task to fix that in the user guide for the next version of the Report Generation Toolkit.  I'm glad you got things straightened out.
-D
(2,938 Views)
