Error 1 while building a DLL
I have programmed some signal processing project libraries in LabVIEW and would like to use them in a VC++ program.  When building the DLL under LV 8.0, I get this error 1 message:
Error 1 occurred at ABAPI Dist Define VI Prototype.vi -> ABAPI Dist Verify Proto Defined.vi -> ABAPI Build Shared Lib With Old Proto.vi -> DBEP_Invoke_Build_Engine.vi -> DBUIP_Build_Invoke.vi -> DBUIP_Build_Rule_Editor.vi -> DBUIP_Item_OnDoProperties.vi -> DBUIP_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  An input parameter is invalid.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
Any clues?
swhich
Message 1 of 1
(2,535 Views)
