Error 1 occurred at Get Queue Status in NI_LVConfig.lvlib:Get File Path.vi->NI_LVConfig
Dear ALL :
use to Labview 2011 compile on the WIN7,show this Error .
I try to installed to on the XP, also show this Error .
                       Ths~
Error 1 occurred at Get Queue Status in NI_LVConfig.lvlib:Get File Path.vi->NI_LVConfig.lvlib:Close Config Data.vi->PCVS_INI.vi->PCVS_Main_V2.8.2.2.vi
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488: Command requires GPIB Controller to be Controller-In-Charge.
(5,061 Views)
In general it means there is an error while trying to load a file which was given as path and it is invalid.
-Can you give more details and maybe the code which you are trying to use?
uday
(5,034 Views)
when Compile to my program ,show this photo
(5,027 Views)
Dear All:
    environment  :  setup
(1) Vision Development Module 2011 ,
(2) Labview2011,
(3) Vision Acquisition Software September 2011
(5,012 Views)
I expect udka was hoping you might attach the VI that is calling this code, so that readers could determine likely causes of the error in terms of the path construction.
GCentralI'm attending the GLA Summit!
(5,007 Views)
Actually, it means there is an error while trying to close a file which was given as a refnum and it is invalid. Possible reason(s) says IF "...the input is a path, the path might contain a character not allowed...". The input is not a path in his case. Possible causes might be that the refnum was null or already closed.
(3,046 Views)
