Error 1 in TDMS write for 64-bit labview
I've come across a weird problem.
In my application, I need to write into a TDMS file with a lot of channels.
The attached file works well in 32-bit Labview. But in 64-bit Labview, it returns error 1 at TDMS write.
Can anyone figure out why it's happening?
(To reproduce the problem, download the attachment and run in both 32-bit and 64-bit Labview)
Thanks.
(2,650 Views)
It is a known bug of TDMS in labview 2010 64-bit.For a workaround,you can pass in 1D arrayor decrease the 2D array size in your sample, like down to 2000 x 500.
Best Regards.
(2,616 Views)
