EpicsCASServer
This .vi works well with LabVIEW 2011 (32), but when I check it with LabVIEW 2018 (64), I get an error of "Check registration of EpicsCASServer".
Any suggestions!
Message 1 of 8
(3,803 Views)
Hi BaJa,
did you try the suggestion I gave you last week?
Message 2 of 8
(3,801 Views)
your suggestion of last weak was not helpful in such a case, I solved that problem by installing an additional driver. but the current is a different issue.
Message 3 of 8
(3,789 Views)
Hi BaJa,
can you attach the original LV2011 version of your VI?
Again you are trying to setup communication to some other software using a 64bit version of LabVIEW instead of the older 32bit environment…
Message 4 of 8
(3,785 Views)
the previous attached is already coded by LV2011.
Message 5 of 8
(3,782 Views)
Hi BaJa,
The attachment in your first message was saved with LV2018.
I repeat: Can you please upload the (original) LV2011 version of the VI?
Message 6 of 8
(3,762 Views)
Message 7 of 8
(3,755 Views)
Hi BaJa,
as anticipated you are using an old ActiveX component, so my previous suggestion still is valid: use a 32bit LabVIEW environment to communicate with those old 3rd party software!
Message 8 of 8
(3,750 Views)
