Entering table values
My front panel looks like this
When I run the vi it allows me to enter values in the rows of table Setpoint Profile, but does not allow me to enter the column headers. The table properties are normal, 5 row2, 2 columns, show column headers, scroll bars etc. What could be the problem?
(3,941 Views)
Headers are not directly writeable at runtime (seems obvious). You can modify them via property nodes and suitable code, for example.
Tables are strings and better suited as indicators. If you use them for numeric inputs, there is no validation that the input is reasonable unless you use some validation code.
(3,938 Views)
There's a table property called "Editable Headers".  Turn it on.
(3,925 Views)
Are you expecting to change headers during runtime? If the headers will remain constant, just initialize the table with theses column headers outside of the while loop.
(3,878 Views)
I have found your  another query for the same application but with different problem and i saw your problem fixed, Make sure you accept solution if you get your expected solution.
(3,857 Views)
Thank you for your help. I was able to find the mistake I was making and fix it.
Girish
(3,834 Views)
I think the real mistake is to use a table and headers for user input. Tables should really always be used as indicators, even though they are named "table control" in the palette and are controls by default, which has always puzzled me. 😄
(3,826 Views)
