Enquiry about missing file in program attached
Hello everyone
I have project anc and i am interested in finding labview program that help me minimize my time as i have worked WIth cancellation the noise for anc and from the basic theories studied and phase shift which i found it doesn't work in real in terms of effective things such as hardware delay >>>
i found program but I couldn't run the program as it is said that some file ( input and output data ) file is missing or have been moved and i am using labview 2011
this program and code will help me a lot please any idea how I fix this please
is it programming data files or what is it exactly and how I cloud solve this issue to make the program work
Message 1 of 16
(4,326 Views)
I believe the missing VI is from the Adaptive Filter add-on. Have you purchased that?
Message 2 of 16
(4,313 Views)
You probably need the adaptive filter toolkit.
(... and keep the discussion in one thread, please)
Message 3 of 16
(4,309 Views)
http://forums.ni.com/t5/LabVIEW/Experimenting-active-noise-cancellation/td-p/424024/highlight/true/p...
It's on this page where you probably got the main VI. Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 16
(4,305 Views)
No, this is not from a toolkit.  It looks like a convolution filter so I'm sure it won't be long until we get a request for an appropriate impulse file...
Message 5 of 16
(4,303 Views)
thanks all
basically isnot about vi missing is about programing file as the labview used for making the program is  version 2007 so will i be able to find files that matched with labview 2011 i really need the file .... thank you very much all
Message 6 of 16
(4,297 Views)
I don't understand.  There is nothing in those old VIs that would prevent them from opening in LabVIEW 2011.  I just opened them in LabVIEW 2013 with no problem.  Did you try???
Message 7 of 16
(4,291 Views)
The program you attached is in version 2011. There is no such thing as version 2007. The only thing missing from the VI you attached is the subVI everyone has mentioned so the issue does appear to be a missing VI. I don't understand why you say the issue is not that.
Message 8 of 16
(4,288 Views)
Hello all
no I have only labview 2011 i don't have this kind of version is it necessary to install this version ..... Can the program be modified or ignore this file  and it can work ? What do you think
thank you
regards
Message 9 of 16
(4,287 Views)
Message 10 of 16
(4,283 Views)
