Enqueue Process is delayed and struck
Hi team ,
I am using Queued message handler architecture Using one Producer loop and using one consumer loop .
Automation was like a when a user clicks on start button , one set of sequence of test case was run and completed after that again user  will click on start button to load same set of sequence for UUT testing .
During the first time there was no delay or struck when running the code . for the next time when i click on start button it takes nearly 20 - 30 seconds for next sequence load and run . what will be the issue ? weird
I probed and find that enqueue had a issue and there is no issue with dequeue .
what should be the process rate ? timeout for both enqueue and dequeue
please find attachment of enqueue and dequeue vi's
(2,539 Views)
Hi Mrtechie,
The problem is in the VI(s) where you call those En-/Dequeue subVIs.
Unfortunately you didn't attach them as well…
Why do you think so? Which "issue" did you notice?
Btw. I think your Dequeue also has a problem: it only dequeues when a certain condition is met (equal to "loop"). What's the point of that? Does the first queue element ever change when the condition is NOT fulfilled?
(2,528 Views)
Shouldn't the enqueued element where the condition is met (equal to "loop") contain the desired data (string "event" & variant "Data"), so you shouldn't dequeue another element rather return the very element which met the condition?
Greets, Dave
(2,507 Views)
Spoiler
hi gerdw ,
Initially i used 2 consumer loops . but after that i removed that consumer loop . so only i mentioned only one producer and one consumer loop and no conditions are set and doesn't change  . condition will be always satisfied . i checked .
i guess process rate ( timeout ) need to changed for enqueue and dequeue . what should be a ideal one . please advise
shall i add more delay ( timeout in ms) in enqueue ? .
In Producer loop  i enqueued set of testcases when user clicks on start button
Based on results of UUT , In consumer loop also i enqueued set of test cases based on the determination of UUT behaviour .
(2,500 Views)
Hi Dave,
The first operation uses QueuePreview so you still need to dequeue afterwards. This whole VI is "interesting"…
Why do you want to add timeouts? This way you will not dequeue the desired elements faster from your queue.
Again I ask for the mainVI as it is important to detect the problems with your en-/dequeuing…
(2,490 Views)
