End lines in XML files
I use LabViews XML parser to edit some XML files. Everything is working fine, but one thing bothers me - all the appends etc are done in a single line. Since I append ~50k children to a node it start to be a problem, as it produces a very long line in the XML, that makes it very hard to edit manually or even to view.
Is it possible to change, so that the LabView will add end-line characters (any kind of them would be good).
Message 1 of 9
(6,606 Views)
Perhaps there isn't a problem with the way LabVIEW is saving the files, but on how you are viewing them.  LabVIEW uses a single newline (I think).  If your viewer is expecting cr+lf then you might see what you are seeing.  View it in notepad ++ and you can see if there are any EOL.
Bill
CLD
(Mid-Level minion.)
Message 2 of 9
(6,581 Views)
I have checked this, as suggested, in Notepad++ (that I actually use to view these XMLs by default) and still there is no CR or LF at the end of the nodes.
This is not crucial, actually, as the XML definition does not ask to have these end-of-lines - it only parses tags (and this single-line format is okay for any XML input) it is only a problem for human viewing of the file... and the fact that this line is 11 558 805 characters long Robot Sad
Message 3 of 9
(6,552 Views)
Add a newline between > and < 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 9
(6,547 Views)
/Y
This will definitely work, but this is as elegant as parsing XML only with Match Regular Pattern VI - not my pair of shoes. Smiley LOL
Message 5 of 9
(6,542 Views)
There are other XML parsers for LabVIEW ...  [The XML produced will be slightly different, but consistent].
Message 6 of 9
(6,527 Views)
I'm aware of this Bob, but I'm limited here and have to use this tool.
Message 7 of 9
(6,521 Views)
Accepted by topic author nikodem
What you want is a pretty print XML.
You can do that with an XML invoke node. There is an option to save the document normal or Pretty Print.
Message 8 of 9
(6,512 Views)
Simplest and best solution!
Message 9 of 9
(6,498 Views)
