End character to if-statement on formula node
Hi, this must be dumpiest question over the history, but I can't find solution, so have to ask here 🙂
I have lots of chemical forms in one formula node and I want to use if-statement to select them. Is there any character to end if-statement? (end if)
other language:
{if A=B}
X=1
{/if}
{if A=C}
X=2
{/if}
_____________________
Now if I try to do this same in labview
if (A=B);
X=1;
if (A=C);
X=2;
It will return value 2 every time.
Thx
-Recon
(3,335 Views)
What is A, B, C?
Look at the case structure, A is your selector, B and C are the defined cases and a catch all default can return if A is undefined.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,325 Views)
Are you using an inline C node?  If so, I'd imaging you end your if statement however you would do that in normal C code.  Otherwise, I would do the following in the code...
(3,324 Views)
