Encrypt a config file
Hello all,
Does anyone have a simple, yet effective way to encrypt a config file?  My config file holds settings and I would like to be able to encrypt it so that no one could open the file in Notepad/Wordpad and view the settings.  The encryption does not need to be very complex, just good enough so that it wouldn't be readable in Notepad, etc.  Thanks!
(4,026 Views)
You can XOR it with a "secret word". It's very simple, and the encription routine is the same as the decription. Simply convert both strings to an array of U8, and xor each element. If the secret word array passed it's last element, begin at the start (use a qotient & remainder, with the I and the array size-1).
Wiebe.
"PaceLT1" <x@no.email> wrote in message news:1159971007444-423610@exchange.ni.com...
Hello all,
&nbsp;
Does anyone have a simple, yet effective way to encrypt a config file?&nbsp; My config file holds settings and I would like to be able to encrypt it so that no one could open the file in Notepad/Wordpad and view the settings.&nbsp; The encryption does not need to be very complex, just good enough so that it wouldn't be readable in Notepad, etc.&nbsp; Thanks!
(4,012 Views)
Convert your string into an array of U8 and then do some math:
shift bits, XOR  Add something.  These actions are reversable!
You could even rotate the array.
Ton
My LabVIEW Ideas
(4,011 Views)
Thanks for the tips guys.  They worked like a charm....
(3,990 Views)
