Encoder giving different count in opposite direction
I am using an E series DAQ board, BNC-2090 and a linear magnetic encoder. I am trying to count to measure diastance travelled. I am trying out the BNC 2120 Quadrature Encoder.vi just to test this out, and it works. I have channel A connected to PFI8 and Channel B connected to DIO6 for up and down. Here are my questions. This is working, but when I move 1 inch in 1 direction it gives me 220 clk counts. Move the same distance in the opposite direction and it gives me 110. Why could this be? I need to measure distance in both directions. Is there a better way to do this? I also looked up the information on NI.com concerning Quadrature Encoders with E-series DAQ boards. It talks about a vi in there called How to
Count. I can't find this vi anywhere. Any idea where I might find this? Thanks for any assistance.
(3,939 Views)
I tried to find that VI, How to Count.vi, and I am under the impression that it is for older versions of DAQ. I have 7.0 installed with DAQmx, and I was unable to find it in the Example Finder. However, I wouldn't worry too much about that; I believe the example was using Traditional DAQ, which is a little bit more complicated to configure for counter operations.
I was reviewing that example you mentioned. Maybe you are getting that count because of the way the code was done; that code is supposed to be used for the quad encoder that comes on the BNC-2120. Here's a KnowledgeBase that links to a couple of examples that should be useful:
Making a Position Measurement with an STC Board and NI-DAQmx
http://digital.ni.com/public.nsf/websearch/A34ACBA6904D619486256E5
C006E5618?OpenDocument
I hope this helps!
GValdes
(3,939 Views)
Working on upgrading to V7.1, but for now only 6.1 is available to me. It seems that the quad encoder works, just counting differently in opposite directions. I have it connected so that PFI8 is the clock and DIO6 is the up and down pin. Works pretty slick and I am now trying to break it down so I can tell when it is going in the different directions. Basically I have to figure out which phase the two signals are in which is giving me fits. I can't wait to get my hands on 7.1 so I can possibly make these tasks easier. Thanks for the links.
(3,939 Views)
I had the same problem. the reason for that is you didn't wire the digital ground of the encoder signal to the digital ground of the card. I had the same problem which was that the encoder reading at one side was half of the value on the other side.
Try this...
(3,939 Views)
