Enable channel on RMX-4003 active load in RMX-4002 rack
Hi!
I would like to remote controll my rmx-4003 eload from labview. I made this simple VI (attached) to do a constant current mode. When I run the VI with channel 1 and set 0,5 A on the mainframe screen the 0,5 A appears everything looks good but on the rmx-4003 screen the current will be about 0,04 A. (its attached to a DC power supply) If I press the LOAD button on the rmx-4003 it current measurement become zero ( disabled the channel) but if I press again to enbale the channel the load will be the asked 0,5 A. In shorttly after run the VI, a disable-enable button press needed to work well. Any Idea? I tried to do this OFF-ON inside the VI but didint worked, only if I press it manually.
(627 Views)
(625 Views)
