Enable and disable events programatically
hi.
i use event case and i want to enable and disable some events programatically. for example sometimes i want to have an event for a button and sometimes i don't want. how can i do this?
thanks.
ali mootab.
(4,410 Views)
A simple solution could be to place the event operations in a case structure, as in the attached example.
Chilly Charly    (aka CC)
(4,394 Views)
@ali mootab wrote:
hi.
Another approach would be to set the Disabled property of the control in question.
0 means enabled, 1 means disabled and 2 means diasbled & grayed out.
Usually 0 and 2 are the most used since it is a good idea to give the user some feedback that a control is not currently operable.
Rolf Kalbermatter
Message Edited by rolfk on 04-16-2006 08:12 PM
Rolf Kalbermatter  My Blog
(4,387 Views)
rolfk a écrit:...Another approach would be to set the Disabled property of the control in question.
Sorry rolfk, but the Disabled property doesn't affect the response to events (at least on my Mac...). The mouse down event is generated even with a grayed button. And this looks normal to me 😉
(4,380 Views)
(4,379 Views)
Hi Ali,
      Not to beat this to death, but in fact you can enable/disable events programmatically. Smiley Happy
Cheers.
When they give imbeciles handicap-parking, I won't have so far to walk!
(4,375 Views)
If you use mouse events then yes you are right. But usually it is about the Commit or Value Changed event and here Enable/Disable works perfect.
Rolf Kalbermatter
(4,362 Views)
