Empty Values
Does LabView recognize an empty or null value in a numeric data set ?
Sometimes the result of a measurement is an invalid result, but it is desirable to record that a measurement was taken for that element in the data set. For example a typical probe data se sequence is
X Y VALUE
3 2 27.2
3 3
3 4 34.2
where the second line is a null or empty value. These values should contribute to the count of the toal number of items in a data set, but should not contribute to any of the statistics - such as the mean.
Thansk
(3,792 Views)
Try -Inf or +Inf
"JDAY" wrote in message news:5065000000080000006C1B0000-986697009000@quiq.com...
> X Y VALUE
> 3 2 27.2
> 3 3
> 3 4 34.2
> Thansk
(3,792 Views)
The only way i have found to achieve this is to put a NaN (not a number) value where null data must be, and before making any calculations (as mean) take it out from the array locating this type of value.
Hope this helps
(3,792 Views)
In order to regconise a null/ empty value in numeric data set, you may wanna to try converting the null/empty VALUE to string, and check using the function if it's a "empty string".
Then, use the output of the function for appropriate actions.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,792 Views)
In order to regconise a null/ empty value in numeric data set, you may wanna to try converting the null/empty VALUE to string, if necessary, and check using the function if it's a "empty string".
Ian F
依恩与LabVIEW
(3,792 Views)
