Embedded Software Evaluation Kit LV8.6 remote web panel
I have recently purchased the Embedded Software Evaluation Kit which comes with LV8.6 90 day evaluation of FPGA, RT... and although I have sucessfully worked through the tutorial that with the kit I came across a problem when trying to run a remote web panel such that it showing loading 0% but never proceeded past this point.
After trawling through many discussion forums I came across a post which gave one of the reasons for this to happen as being due to having a newer version of LabVIEW run time engine installed on the PC - only by removing LabVIEW 2011 could I get the web panel to run.
My question is how do I manage multiple version of LabVIEW if I wish (and I do wish) to install more than one version of LabVIEW and still be able to run a remote panel via LV8.6?
Cheers,
Helen
CLD, CTD
(2,621 Views)
Accepted by topic author HelenC
Hi Helen,
With development versions of LabVIEW you can deactivate them (using the NI license manager), but since the run-time engines are not licensed you can not deactivate that.
You could try running one of your LabVIEW versions in a virtual machine, thus separating them from each other.
I apologise for the problem that you have encountered, I appreciate that it inconveniences you quite a bit, but I assure you that your R&D team are looking into the issue.
Kind regards,
James W
Controls Systems Engineer
STFC
(2,594 Views)
Hi James,
Thank you for your reply.
Your virtual machine solution does provide me with a work around - just need to google how to go about this!
Kind regards,
Helen
CLD, CTD
(2,587 Views)
