Embed string into JPEG files
Thank you very much Darin.K.
You have been a great help to me.
- Sable
Message 11 of 16
(975 Views)
Darin.K,
After adding the ascii exif, must we save as a new jpeg file (or) is there a way we can save the changes on the jpeg file read itself?
- Sable
Message 12 of 16
(953 Views)
Just use the same filename to overwrite the file if you so desire.   I always write to a new file during testing.
Message 13 of 16
(944 Views)
Message 14 of 16
(935 Views)
I guess I would not run into that issue in my workflow since I very rarely do any type of 'in-place' work on a file.  My reasoning being that if something goes wrong you are likely to end up with a corrupted file.  Instead I usually write a new file with the old name to a different directory, and if I am certain that worked, then I *might* go back and delete the original.  I tend to be a data hoarder to I tend to keep originals.
You will have to do some combination of write to new file, delete original file, and renaming/moving.  I would use the file constant to get the temp directory and write a new file with the original name to there.  Then I would delete the original jpeg and move the new file into the original directory.
Message 15 of 16
(928 Views)
Thank you Darin.K
- Sable
Message 16 of 16
(920 Views)
