Eliminate margin around Xcontrol
Hello, all!
 I'm trying to create an Xcontrol using a combo box on the FacadeI would like to adjust the Facade window size so that when I drop the Xcontrol onto a panel, there is no space between the edges of the combo box and the Facade windowI've tried to adjust the control and window sizes manually, but it's been a frustrating process, to say the leastNo matter what I do, the Xcontrol window is always larger than the combo boxAny suggestions?
Slowpoke
Slowpoke
CLAD (believe it or not!), using LabVIEW 8.5
They don't call me "Slowpoke" for nothin'!
(2,733 Views)
I didn't have a specific problem doing this. What version of LabVIEW are you using? Is the attached (LV 8.2) what you're trying to do?
(2,715 Views)
