Eliminate empty string elements in an array
Altenbach,
                    My problem was i could only transmit 8 bits through my usb controller.So i will be sending 30,00,000 of data and i need to convert this back to 15,00,000 of 16bit data and i will convert this back to an image.
Thanx a ton for the suggestion altenbach.You are right i am not very conversant with data types. Sure will take up your suggestion.
Message 11 of 19
(2,795 Views)
Just a little info altenbach.The inplace function u see was suggested by you again.Thanx once again
Message 12 of 19
(2,793 Views)
Hi altenbach,
                       I am getting this
Message Edited by muks on 08-30-2008 07:58 AM
Message 13 of 19
(2,787 Views)
My expected output is this altenbach. I think i misunderstood your suggestion.
Message Edited by muks on 08-30-2008 08:00 AM
Message 14 of 19
(2,784 Views)
You lost me here. I don't see any "inplace" function in any of your code, so what exactly do you mean by your statement?
muks wrote:
                       I am getting this
You really have a serious problem with even the simplest code. 😮
Of course you will get a different result if you wire up a completely different program than what I suggested!!!
  • In my image the type is a U16 array, so why in the world would you change this to I64??? Makes no sense at all!
  • Why did you change "little endian" to "big endian"?
Message 15 of 19
(2,768 Views)
NOOOOO!!!!!
This is NOT how you join 8 bit values to form 16 bit values! This is total garbage! 😮
Remember that 8 bit values are as follows (displaying all 8 bits)
00000001 (1)
00000010 (2)
00000011 (3)
00000100 (4)
So, after joining in the correct byte order, we get two 16 bit values:
0000001000000001 (513)
0000010000000011 (1027)
The way you are joining the values is completely meaningless and ambiguous, because there is no way to reconstruct the original data from the result. With your method, a result of 10011 could have come from e.g. [0:10011], [100:11], [1001:1], etc. with equal probability.
Attached is a quick draft, see if you agree with my results! 🙂
Message Edited by altenbach on 08-30-2008 10:07 AM
Message 16 of 19
(2,763 Views)
Just for completeness, here's another very simple alternative. 🙂
Message Edited by altenbach on 08-31-2008 06:33 PM
Message 17 of 19
(2,717 Views)
 Thanx for pointing that ou.I totally agree. The inplace function i mentioned was used inside the while loop of serial communication.
Message 18 of 19
(2,704 Views)
There is no inplace function, but you can do certain operations "in place", e.g. using shift regsiters and replace operations. Still you need to initialize the array with the correct representation, U8 in this case.
LabVIEW 8.5 and higher has the "in place element structure" (see image), it can be useful sometimes. I first thought you were talking about this. 😉
Message Edited by altenbach on 09-01-2008 12:15 AM
Message 19 of 19
(2,692 Views)
