Element-by-element multiplication of a vector with matrix rows
the problem is solved with the Matix A x Vektor, but what if the values of the Matrix and the Vektor are komplex numbers. The A x Vektor function doesn't work with komplex numbers. Is there possiblilities to deal with the problem anyhow?
thanx!
Message 11 of 13
(1,656 Views)
Well, you can always make your own from scratch. 🙂
The attached code image does the A x Vector for complex numbers.
(edit: fixed image)
Message Edited by altenbach on 03-26-2005 03:53 PM
Message 12 of 13
(1,652 Views)
Actually, up to LabVIEW 7.0 there was a complex "A x Vector.vi" in the "Complex Linear Algebra" Palette.
In LabVIEW 7.1, the generic "A x B.vi" has been made polymorphic and now accepts matrices and/or vectors of many data types, including complex. 🙂
Quote from the help:A x B Performs the multiplication of two input matrixes or an input matrix and an input vector. You can use this polymorphic VI to perform multiplication for real matrixes, complex matrixes, a real matrix and a real vector, or a complex matrix and a complex vector. The data types you wire to the A and B inputs determine the polymorphic instance to use.
So, this is the way to go! Disregard my previous answer. 😉
Message 13 of 13
(1,641 Views)
