Elapsed time with VISA Read
In my VI inside case structure, I am using VISA read with 10 sec timeout, In the mean tiime I also want user to show total number of second elapsed waiting for read by VISA.
In my application after user scans the serial number than user need to connect ECU within 10 seconds(VISA timeout). In the mean time I need to show user this message
Connect ECU in 10 sec.
Connect ECU in 9 sec.
Connect ECU in 8 sec.
Connect ECU in 7 sec.
Thatswhy I need elapsed time or any other method is welcome. Attached VI for reference.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 9
(3,488 Views)
Two possibilities.
Make the timeout 1 second, and put the VISA read in a For Loop that runs 10 times.  Code to update string in there, and if the VISA read does not timeout, then it ends the For Loop early.
Another, separate while loop adjacent to the VISA read that updates the string display.  Where the VISA read, have it set an occurrence that tells the while loop to stop.
Message 2 of 9
(3,470 Views)
@RavensFan wrote:
Two possibilities.
Thanks for the quick reply.
For the first, I think I shouldnt go for VISA read in loop becasue that might lead to data loss. If I use while loop then its incrementing after VISA read. Both are not running parallely. I think for that also I need to use while loop wisely for VISA read too.
--Ranjeet
Message 3 of 9
(3,466 Views)
How do you think a read inside a loop is going to lose data and why on earth would you start a loop after instead of in parallel?
Message 4 of 9
(3,446 Views)
Its all about timing and it is independent of PC. I mean to say if I normally use VISA then it will wait untill all data or termination char is matched and hence sure that data cant missed. If on other PC timining didnt matched then data might lost.
I know it wont but might possible
--Ranjeet
Message 5 of 9
(3,442 Views)
I think I don't understand what you just said.
Message 6 of 9
(3,436 Views)
you see if I dont use loop then VISA read will wait untill complete or termination char is met. If I use loop than might posible that becasue of timing mismatch data lost.
without loop VISA polls the data continous sure that data will not lost
--Ranjeet
Message 7 of 9
(3,424 Views)
You'll only lose data if you decide to discard some.
Message 8 of 9
(3,418 Views)
No I will not do that intentionally Smiley Very Happy.
So you suggest reading in while loop. Let me try that also.
--Ranjeet
Message 9 of 9
(3,415 Views)
