Elapsed time Trouble
I am trying to essentially turn on an led for a given amount of seconds and then turn it off.
Two problems i am faced with,
I. on the DIO, the LED is always on, as soon as i make the connection from daq to the board. How can i prevent this, if i can.
II. after the specified amount of time, the LED does not turn off. Im not suring if im making the right connections on the VI.
Please find attached the VI.
(2,470 Views)
assuming your Daq DIO is an open collector with internal pull up resistor, that is why you see a Hi at start...
depends on how you hooked the DO to a led(anode/cathode)? connected as cathode(neg turns led on) or as anode(pos is on)
(2,465 Views)
