Elapsed Time Problem
Hi Slurpee,
I didn't run your code because you will face problems to get a stable dt. What you should do is open the file once and write to the reference. To do this you should write your 1d-array of dbls, not directly but use the array to spreadsheet string from the string palette. The outputted string can be written into the write string to file.vi.
Ton
My LabVIEW Ideas
Message 11 of 11
(417 Views)
