Efficient string buffering
I have a logging application that receives ~50-150 character strings (variable size) at variable rate over ethernet, sometimes in bursts of up to 1000/sec.
I have implemented a FIFO buffer as subVI that has two main modes (In addition to (0) initialization, etc):
(1) write to buffer
(2) read all and clear buffer.
Function 1 is used in a tight loop listening on an UDP port and stuffing everything unseen into the buffer.
An independent loop reads the accumulated data asynchronously for post processing, filtering, and display of selected events. The current buffer size is 1024 entries which is sufficient unless I run it on my old '486/66.
So far, the buffer is implemented as array of strings, optimized for maximum "inplaceness" as I w
ould do it for a numeric buffer, but due to the nature of the variable string length and the way strings are handled and stored, I wonder if this is the correct thinking.
(I've been running it for weeks without problems and there is no increase of allocated memory or anything else fishy, so LabVIEW seem to manage it well)
Would it be better to implement the buffer as a preallocated 2D array of I8, rolling the strings into sucessive colums (after string to byte array) and storing the length as first element?
Are there any other alternatives that I haven't considered?
(2,955 Views)
There are two quesions you need to ask yourself here:
"Does it work?"
"Will it be worth it to change the way I do things?"
First of all, it works, so I wouldn't change things. You aren't running up too much memory. Second, what you are proposing to do is to do your own version of what LabVIEW (I think) does with strings anyway, but on the output side, which means it may actually take a bit more to do. At any rate, I don't see that you need to change your methodology.
Your alternative methodology, without spending too much time thinking about it, seems to be optimized. Again, if your current method works, leave it. It makes the program easier to understand anyway.
As an aside to this, if you wanted to play around and try to get this alternati
ve method working, you should play around. You may or may not like the benefits, but any experimentation of this type is new information that can only serve to benefit you in the future. If you build your subVIs correctly (generic enough, or scalable/configurable), you could create yourself a great toolkit for future use.
(2,955 Views)
