Editing the waveform graph
    I have encountered some problem is finding waveform graph. I downloaded the tutorial for ASK modulation i tried to do a new one as practice. But the graph are very different. it seems that the borders are transparent which can only see the graph portion only. I have tried to use waveform graph from the graph palettes. I edited it by stretching the graph (waveform result) area and unchecked the visible plot legend, scales and etc.. but i just can't do it the same as the example and the waveform at the bottom is slightly different also (but i don't know isit different scales). I have no choice but copy the graph and paste on mine. Anyone know the trick or tips in doing it? Thanks..
(3,145 Views)
Hi Serina,
have you tried to use the waveform graph/chart from the "Classic" palette?
Those controls/indicators have a "flat" look making a lot easier to hide unneeded featuresSmiley Wink
(3,143 Views)
yes i used the graph from the classic palette but i did not see any control or option i can use to apply "flat" or other name to hide unnecessary features. can you kind enough to tell me if you happen to know it..Thanks!Smiley Happy
(3,116 Views)
How about trying to use the paintbrush on the tools palette and selecting 'transparent' as the color? After you select the paintbrush, right click on the area you want to color and when you get the color palette, select the 'T' in the upper right hand corner.
(3,108 Views)
    It works! Thanx alot..i have learn 1 more tips again..Thanks again..Smiley Wink
(3,104 Views)
