Editing tables ( changing cell entries , inserting rows etcat runtime
I have a table indicator with entries that I may want to edit before proceeding with my program. Is there a way to turn this same table into some sort of a control after initially working as an indicator and displaying the iinitial entries,, so I can make modifications to it ?
[BADGE NAME]
(4,443 Views)
you just can change indicator into control and vise versa when vi is not in run mode
if you want manipulate data of indicator in run mode you have to use local variable or property node (value)
(4,433 Views)
I am aware of property nodes but not quite sure how that helps in this particular case given that I need the user to be able to make the entry without having two separate tables.
I dont understand your last phrase " interest in image processing and Labview"
[BADGE NAME]
(4,431 Views)
may be this exampe could help you
(4,418 Views)
Thanks Hatef with interest in image processing and labview 🙂 I just found a solution that suits me
[BADGE NAME]
(4,415 Views)
Actually with your sudden interest in "image processing and Labview I am not sure I want that vi on my machine. Atleast not more than i already have 🙂
[BADGE NAME]
(4,409 Views)
I do not really understand what is your means
about that phrase ?!! where did you see such sentence in my answer?!
(4,399 Views)
