Edit control right click menu
Just to start out, I'm running LabView 8.0.
I know that you can go into a control and create a .rtm file to give you a custom right click menu while your .vi is running. But I'd like to be able to enable and disable portions of that menu while the .vi is running. Is that possible? Or, is it possible to dynamically create a custom right click menu while the .vi is running?
Thanks!
(4,682 Views)
(4,667 Views)
