Edge detection using IMAQ Find Edge/IMAQ Edge Tool 3
I have several images with useless background around a rectangular ROI (coordinates unknown!). So I tried using the two VIs mentioned above in order to detect these edges so that I can remove them. Regretfully, this does not work as planned.
IMAQ Find Edge usually finds an edge, but not where it should be. The edge detection is earlier than I want it to be.
IMAQ Edge Tool 3 sometimes does not find an edge at all, sometimes it finds the edge perfectly. Here I use the 'get best edge' option, which delivers the best results with all the images I tested it with.
All the other options are also not changed while running the VI with the images I have.
Does anyone have intimate knowledge of these VIs' algorithms, how they work, how they can be manipulated, ... ?
(3,901 Views)
Hello LordSnow,
in this folders are the manuals C:\Program Files\National Instruments\Vision\Documentation
the NIVisionConcepts.chm (under Machine Vision --> Edge detection --> Concepts) describe how it works.
I hope this helps if not, can you post the code and some pictures with a describtion, what should be detected?
best regards
Alexander
(3,868 Views)
Can you upload an example image?
That would clarify what you're trying to do?
Most of the time a change of mindset solves the problem.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,849 Views)
Some might not find the documentation in the Program Files area.
Later versions of windows installation put the documentation here:
C:\Users\Public\Documents\National Instruments\Vision\Documentation
(3,066 Views)
