Easy question...
Is there a way to run DOS commands from LabVIEW? I'm sure there is, but
I can't find it. I just want to execute a simple batch file (.bat).
Any ideas?
Rick
rick@csciences.com
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
(4,137 Views)
It's hidden in the communication palet (well in 5.1 it is anyhow).
Drop the 'system exec' onto your diagram and create a constant on the
'command to execute' terminal. Type in your batch file name (and path if
needed) and away you go.
Rick Nelson wrote in message <379F20FE.418BC9BE@csciences.com>...
>Any ideas?
>Rick
>rick@csciences.com
(4,137 Views)
Under "Communications" use "Exec"
>Any ideas?
>Rick
>rick@csciences.com
(4,137 Views)
